Go Back   Skyline Owners Forum > Technical / Performance / Maintenance / Help > Tuning, Technical Questions
Forum Rules Register New Garage Online Shop Calendar Mark Forums Read
Tuning, Technical Questions Use this Forum to talk about all things technical & tuning
Reply
Thread Tools Rate Thread
Old 23-09-2009, 12:07 PM   #1
richy
richy's Avatar
Club ID#: 3562
fitted pfc now blue relay in boot clicking ?
got my power fc today put it on car turned ignition on and this clicking started, i looked in the boot and it is a blue relay next to fuses ?
car would not start put standard ecu back on and no noise and car started ?
what is this blue relay ?
thanks people
__________________
My RB26 GTST Drift car build -
http://www.skylineowners.com/forum/s...d.php?t=100408
my rb 25 rebuild -
http://www.skylineowners.com/forum/s...t=rb25+rebuild
richy is offline   Reply With Quote Share on facebook
Old 23-09-2009, 01:52 PM   #2
NISFAN
NISFAN's Avatar
Drives: Skyline GTS R33
Club ID#: 484
Fuel pump relay
NISFAN is offline   Reply With Quote
Old 23-09-2009, 02:24 PM   #3
richy
richy's Avatar
Club ID#: 3562
i thought it might be but why would it click with pfc and not with standard ecu ?
__________________
my rb 25 rebuild -
Old 23-09-2009, 02:28 PM   #4
NISFAN
NISFAN's Avatar
Club ID#: 484
Does it prime when you switch on ignition?
If it does that fine, then the PFC might be having problems reading your CAS or something. It should give the FP the signal to run, when the PFC sees engine revs (i.e. whilst cranking and running). If the CAS signal is not being read properly the PFC might see revs/no revs/revs/no revs, etc and turning FP on off in tune. If that makes sense.
Old 23-09-2009, 04:23 PM   #5
richy
richy's Avatar
Club ID#: 3562
the fuel pump does prime, but the commander stays on apexi sign and does nothing else and the relay just clicks like mad
__________________
my rb 25 rebuild -
Old 23-09-2009, 04:26 PM   #6
Smore
So Ireland Area Rep
Area Rep
Smore's Avatar
Drives: 1997 R33 GTST S2
Club ID#: 6567
Country Flag
Quote:
the apexi sign staying on the commander is not a good sign..... can you check the part numbers for the actual power fc and commander? 100% for your car?
__________________
Regards
Simon ( Smore )~ Map and Members
Ireland Section
Xbox360 Live Gamer Tag: Skyline Si
**Upcoming Ireland / UK Meets**
SO.com Offical HKS Whore!
Smore is offline   Reply With Quote
Old 23-09-2009, 04:35 PM   #7
NISFAN
NISFAN's Avatar
Club ID#: 484
So FP relay starts clicking before you even try to start engine?
I agree with Smore, apexi sign is not good.
Do you know anyone with a PFC that can install your PFC into their car, just to ensure all wiring is correct?
Old 23-09-2009, 04:55 PM   #8
richy
richy's Avatar
Club ID#: 3562
yes relay clicks as soon as you turn ignition on ?
hand controller code - 020-22158
ecu - 020-2225
__________________
my rb 25 rebuild -
Old 23-09-2009, 04:58 PM   #9
COOLDRFT
RB25det inside
COOLDRFT's Avatar
Drives: Hcr32.5
Club ID#: 12165
Country Flag
I had the same problem with my r32 when I put a rb25 loom into it.
You have'nt all the power wires conected right.
Think it was a wire coming off the one of the relays next to the ecu.
With the standard ecu in ,when you turn off ignition you should hear a "click" 1-2 seconds after turning the key off. If that's not happening you're wiring trough the relay isnt right.
__________________
For Sale R32 Gearbox "Ireland"
COOLDRFT is offline   Reply With Quote
Old 23-09-2009, 05:03 PM   #10
richy
richy's Avatar
Club ID#: 3562
checked codes and they are correct it was one were you get the commander and ecu in the same box version 3
the click tour talking about is the eccs relay, yes ?
if the wiring was wrong then surely the standard ecu would not work ?
__________________
my rb 25 rebuild -
Old 23-09-2009, 05:09 PM   #11
richy
richy's Avatar
Club ID#: 3562
just had another check, the relay clicks when you turn the ignition on, BUT the fuel pump does not prime then stop as it should, it just goes and goes and does not stop ?
__________________
my rb 25 rebuild -
Old 23-09-2009, 06:16 PM   #12
anthonymcgrath
anthonymcgrath's Avatar
Drives: a pain in the constant backside
Club ID#: 8089
hey Richy
I had a quick google search online and found a thread from a chap with a 180sx. he had a similar problem and got it sorted by grounding the eccs relay as it needs a ground to stay active so to speak. heres the link:
http://www.northwestnissans.com/boar...d.php?t=100642
however I found another thread here. This chap needed to swap the pins from the pfc to the fuel pump relay as it needed to be grounded I think. I'm not sure I'm typing that right as I'm riddled with flu today but have a read of this link mate. if nowt else they should give you things to try out
http://zilvia.net/f/tech-talk/276819...stock-ecu.html
post #20 from the 2nd link:
so seperated the signal wire from the ecu to the pump relay. grounded it at the relay, car fired right up. doing the idle learn as we speak
set it to 50% injector and .12ms for my tomei 740s
vg30 mafs
we will see how it goes, also, should the 02 reading be turned off on the pfc, heard it can be kind of a hindrance, boost controll is turned off
anthonymcgrath is offline   Reply With Quote
Old 23-09-2009, 09:55 PM   #13
COOLDRFT
RB25det inside
COOLDRFT's Avatar
Drives: Hcr32.5
Club ID#: 12165
Country Flag
I had the same problem as I said
The fuel pump + engine worked ok with the oem ecu
But when I plugged the pfc in the pump relay started clicking + car wouldn't start.
I wired the pump up direct from battery + the car still wouldn't start.
The problem is the way the eccs relay was wired ,the pfc needs all 3 12v power supplies.
Does the eccs relay switch off 1-2 seconds after you turn the key off ?
__________________
Old 23-09-2009, 09:58 PM   #14
anthonymcgrath
Club ID#: 8089
hey cooldrft did you look at those forums I linked to? Seems ppl are disconnecting the signal wire from the ecu to the fuel pump relay then grounding the relay. I spoke to richy about this earlier but we were both a bit unsure how to go about doing it.
Old 23-09-2009, 10:15 PM   #15
COOLDRFT
RB25det inside
COOLDRFT's Avatar
Drives: Hcr32.5
Club ID#: 12165
Country Flag
I cut the wire coming from the ecu + grounded the wire going to the pump to the body.
The reason I did it was the pump wasn't drawing 12v.
I'd sort the eccs problem first + take it from there.
__________________
Reply
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 SkylineOwners.Com Ltd
Page generated in 0.49420 seconds with 16 queries
