Go Back   Skyline Owners Forum > Traders Forum > Authorised Traders > MeisterR
Forum Rules Register Garage Online Shop Calendar Mark Forums Read
Reply
Thread Tools Rate Thread
Old 17-06-2010, 05:36 PM   #1
MeisterR
P.R. MANAGER
Authorised Trader
MeisterR's Avatar
Club ID#: 3682
Talking MeisterR Coilovers £499 Intro Offer... £100 Off RRP!!!
I am please to announce an intro offer the MeisterR Zeta-S and Zeta-R Coilovers.
For a limited time, all coilovers will be discounted £100 off RRP for all skylineowners members.
This offer apply to the listed model and are all ready for next day delivery:
SKYLINE ( R32, R33, R34, V35 )
R32 GTS Zeta-S Coilovers £499 + P&P
R32 GTR Zeta-R Coilovers £549 + P&P
R33 GTS Zeta-S Coilovers £499 + P&P
R33 GTR Zeta-R Coilovers £549 + P&P
R34 GTS Zeta-S Coilovers £499 + P&P
R34 GTT Zeta-S Coilovers £499 + P&P
R34 GTR Zeta-R Coilovers £549 + P&P
V35 Zeta-R Coilovers £579 + P&P
180SX / 200SX / SILVIA ( S13 / S14 / S15 )
(Include Camber Adjustment on Front Top Mount)
S13 Zeta-R Coilovers £579 + P&P
S14 / S15 Zeta-R Coilovers £579 + P&P
When choosing a set of coilovers, there are many concerns that everyone have.
Price, Quality, Comfort, Height Adjustability, and these are just a few of the questions most people will ask when looking for a new set of coilovers.
Many people believe that coilovers have to be "stiff", but that is because many coilovers on the market are design for track usage and therefore are design to be use on flat road surfaces with very strong damping rate.
However, an over dampened damper will actually decrease traction on uneven road surfaces.
Not only does this create an extremely uncomfortable ride, it also significantly reduce performance and driver confidence on surfaces that we drive on everyday.
MeisterR decided to develop a new line of suspension specifically for the UK uneven road surfaces and address all the concerns that everyone have.
We experimented with a range of springs rate, damper valving, and different damper stroke travel until we come up with a combination that satisfy our balance of ride comfort, height adjustability, and dynamic control.
MeisterR Zeta-S / Zeta-R Coilovers for Nissan Skyline
(Pictures is off a Honda Civic, will update with the Skyline photos at a later date)
The Zeta-S Coilovers had many adjustments made in order to make the coilovers better for everyday fast road uses. The basic remains the same as before using high quality adjustable monotube dampers, linear rate springs, and a modern dual perch coilovers design. Zeta-S have revised damping specifically made for the UK roads, longer damper stroke travel for the bumps and dips, 32 stage damping adjustment for fine tuning your desired ride, and it is 23% lighter than previous generation.
Zeta-S Aluminium Top Mount with Harden Rubber Bushing.
Anodised Red Aluminium Top Mount replace your old and tired steel top mount.
The harden rubber bushing are able to provide precise steering feedback while absorbing NVH (Noise, Vibiration, Harshness) making it a better option for fast road use.
Zeta-R Aluminium Top Mount with Pillowball Bearing.
The Japanese pillowball bearing increase steering response by removing any possible slack between the suspension and the chassis.
MonoTube Dampers with Black Chromium Plated Body, Cold Coiling SAE9254 Chrome Silicon Steel Springs
MonoTube Dampers ensure high performance damping and ability to dissipate heat under hard usage.
The Black Chromium Plating have endure 120 hours salt spray test under ASTM B117 Standard with no sign of corrosion.
There are 32 stage damping adjustment (Compression and Rebound Combined). Lengthen Rubber Boot ensure the damper piston will be protected from harsh environment.
The Cold Coiled Linear Rate Springs use high grade SAE9254 Steel to ensure strength and provide linear and predictable weight transfer characteristic.
Anodised Aluminium Spring Perch and Locking Collar
Lightweight Aluminium Collars are use to lock your springs and brackets in place.
The "Polyamide" springs isolator are use to reduce noise and spring binding issue associated with rubber isolator.
Aluminium Lower Bracket
Lightweight Aluminium Bracket are used to reduce weight even further.
How to order? Price?
Ordering couldn't be easier. Simply place your order at the MeisterR website ( www.MeisterR.com ) and check out using the secured webshop.
The coilovers specifications are listed in the easy to navigate website.
All you have to do is enter the voucher code below during checkout and your discount will be automatically calculated.
Just put in the voucher code SO100 during checkout to get your Discount... Thats it.
If you have any problem, please feel free to PM me or E-mail me at info@meisterR.com
MeisterR is offline   Reply With Quote Share on facebook
Old 22-06-2010, 08:09 PM   #2
MeisterR
P.R. MANAGER
Authorised Trader
MeisterR's Avatar
Club ID#: 3682
Springs Rate and info can be found on www.meisterr.com
All of the listed coilovers are in stock and will be send out next day delivery once order are placed.
Old 23-06-2010, 07:18 PM   #3
ryanpatterson
ryanpatterson's Avatar
Club ID#: 23565
I need a set of these, but i dont have any money.. Anyone want to buy me some?? lol
ryanpatterson is offline   Reply With Quote
Old 28-06-2010, 09:10 PM   #4
MeisterR
P.R. MANAGER
Authorised Trader
MeisterR's Avatar
Club ID#: 3682
Still on offer and all in stock ready for next day delivery.
Old 03-07-2010, 10:29 PM   #5
Robbs
Robbs's Avatar
Club ID#: 5400
how do these compare to hsd's ? do they go as low and do they adjust in the same way ? as in you shorten or lengthen the shock by screwing or unscrewing the shock into the bottom mount ? or is it done using the locking collors ??
Robbs is offline   Reply With Quote
Old 05-07-2010, 09:46 PM   #6
MeisterR
P.R. MANAGER
Authorised Trader
MeisterR's Avatar
Club ID#: 3682
Quote:
The damper valving on the MeisterR Zeta-S / Zeta-R are specifically designed for the UK / European Roads.
The MeisterR Coilovers will provide compliant handling on the uneven road surfaces that you drive on everyday, but with enough damping adjustments so you can limit your body roll on those odd occasional track days.
Its hard to "compare" how one suspension unit against another one as there are a lot of difference, and one might be better in certain area but worst in another... there are always some "trade off" no matter how you design a suspension system.
The MeisterR are same as the HSD in terms that they are both dual perch construction (you lengthen / shorten the damper body using the lower bracket and the locking collar).
This give the best way to adjust the car's ride height as it will allow independent adjustment of the spring pre-loads, and lowering the ride height will not decrease damper stroke travel.
Some of the things we change on the Zeta-S / Zeta-R is increase its "refinement" which the previous generation of coilovers were lacking.
The 32 stage damping adjustments allow finer adjustment point over the refined damping range.
This is very useful as the previous generation of the Zeta Coilovers had only 15 damping adjustments that was slightly too far apart, especially on the harder adjustment level where 1 click massively change the rebound curve.
Another thing was the new damper coating.
The "Black Chromium" coating was a few that we tested and found to be the best.
We tested the damper in a salt spray tester for 120 hours under ASTM B117 standard and found no sign of corrosion.
There are other bits such as using more light weight material to decrease the total damper weight by about 25%, etc...
I hope that answer some of your questions... if you have any other concerns, please feel free to let me know.
Old 05-07-2010, 09:56 PM   #7
FORUM THIEF
Bigchief's Feltcher
Moderator
FORUM THIEF's Avatar
Drives: 1998 R34 GTT
Club ID#: 11517
Country Flag
Dude, did you go to Santa Pod on Sunday? Was following two RX7's when this pimp people carrier jumped in front of me at the round about. Car was covered in MeisterR stickers
__________________
"WEST LONDON AREA MEMBERS LIST"
If you own a skyline and live within these boundries get your name down:
"WEST LONDON AREA MAP"
UPCOMING EVENTS
Missbanzai London Tunnel Run Sat 16th Oct
My Purple Pervert GTT Project
FORUM THIEF is offline   Reply With Quote
Old 06-07-2010, 03:58 PM   #8
AEROKIT
P.R. MANAGER
Authorised Trader
AEROKIT's Avatar
Club ID#: 11806
can't recommend these enough, we are running a set on our s14.5 and they are FANTASTIC!
__________________
www.aerokit.eu
Europe's largest stockist and manufacturer of Aero Parts
AEROKIT is offline   Reply With Quote
Old 14-07-2010, 10:30 PM   #9
Satansbodyguard
Satansbodyguard's Avatar
Club ID#: 12619
Country Flag
when will you be getting the R32GTR Zeta-R back in stock ?? as mine is coming off the road this month to have suspension/brakes done
thanks
__________________
CRY HAVOC AND LET SLIP THE DOGS OF WAR
Satansbodyguard is offline   Reply With Quote
Old 16-07-2010, 11:07 AM   #10
MeisterR
P.R. MANAGER
Authorised Trader
MeisterR's Avatar
Club ID#: 3682
R32 GTR coilovers will be back in stock about 2 weeks time.
Everything else are already in stock ready to go.
Old 21-07-2010, 08:06 PM   #11
MeisterR
P.R. MANAGER
Authorised Trader
MeisterR's Avatar
Club ID#: 3682
Waiting for some pictures and review back from an R32 GTS... so stay tune for some more info.
Old 21-07-2010, 09:09 PM   #12
bigchief
bigchief's Avatar
Drives: spec 2 R33Gtst
Club ID#: 6924
Country Flag
Mark Luney runs these and is 2nd in the British Drift Championship and he rates them as the best he's used in over 20 years in motorsport, ill up-grade from my coilovers to these for the next drift season Jerrick, great job mate
__________________
Quote:
Originally Posted by mick-skyline View Post
You've never met Keith have ya..... He even looks at a bike it'll crush itself he's like a big bald hulk only uglier
Keith
bigchief is offline   Reply With Quote
Old 27-07-2010, 07:38 PM   #13
MeisterR
P.R. MANAGER
Authorised Trader
MeisterR's Avatar
Club ID#: 3682
Quote:
Yep, Mark is loving his car for sure.
I was jumping up and down when he took the win at BDC Round 4 also.
Just to let everyone know the offer is still on, and most everything is in stock.
Will try to post up some review and pictures off owners ASAP.
Old 04-08-2010, 09:41 PM   #14
dinger-scotland
dinger-scotland's Avatar
Drives: 1993 nissan skyline r33 gtst
Club ID#: 24825
Country Flag
what drop do you get on these
__________________
HKS airfilter, HKS ssqv 3, HKS 1.8mm headgasket, HKS actuater, JAPSPEED turbo elbow, JAPSPEED downpipe, JAPSPEED de-cat, JAPSPEED type 2 system, JURAN shocks, F.M.I.C.
dinger-scotland is offline   Reply With Quote
Old 06-08-2010, 12:01 AM   #15
MeisterR
P.R. MANAGER
Authorised Trader
MeisterR's Avatar
Club ID#: 3682
Quote:
You have a wide range of adjustments in the coilovers, but I would say near standard height all the way to tyres tucking is possible.
You can get around -80mm or so pretty easily as the standard suspension design have alot of room for adjustments.
Reply
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 SkylineOwners.Com Ltd
Page generated in 0.27741 seconds with 15 queries
