Go Back   Skyline Owners Forum > Technical / Performance / Maintenance / Help > Tuning, Technical Questions
Forum Rules Register New Garage Online Shop Calendar Mark Forums Read
Tuning, Technical Questions Use this Forum to talk about all things technical & tuning
Reply
Thread Tools Rate Thread
Old 05-10-2006, 01:33 PM   #1
Nino_Brown
Alloy Junkie
Nino_Brown's Avatar
Drives: 350gt
Club ID#: 6900
Country Flag
How much to supply and fit a HG?
Just a quickie guys,
How much (roughly) should it cost to supply and fit an steel head gasket (Tomei 1.2mm)....?
Also, if the heads comming off to fit the gasket, does it make it an easier job to thro some cams in at the same time?
__________________
"Its better to burn out, than to fade away"
Z-Tube and Invidia Gemini.....more to come!
Nino_Brown is offline   Reply With Quote Share on facebook
Old 05-10-2006, 06:54 PM   #2
SPEARMINT
Banned from Site
Drives: 1996 R33 GTS-T S2
Club ID#: 5285
You can do the cams with the head on no probs. As for the HG, are you supplying it yourself then having it fitted? Or paying someone to supply and fit it?
SPEARMINT is offline   Reply With Quote
Old 05-10-2006, 07:28 PM   #3
Nino_Brown
Alloy Junkie
Nino_Brown's Avatar
Drives: 350gt
Club ID#: 6900
Country Flag
Garage is gona supply and fit, think he mentioned it was around £180 for the gasket....not sure about the labour time tho
Thanks richie
__________________
Old 05-10-2006, 08:03 PM   #4
SPEARMINT
Banned from Site
Club ID#: 5285
Nino, heard of these before?
http://www.cometic.com/sportcompact.aspx
Old 05-10-2006, 08:10 PM   #5
Nino_Brown
Alloy Junkie
Nino_Brown's Avatar
Drives: 350gt
Club ID#: 6900
Country Flag
Nope,
Have you used them?
The guy recommended i get a 1.2 steel HG....
How much should labour do you wreakon?
__________________
Old 05-10-2006, 08:16 PM   #6
SPEARMINT
Banned from Site
Club ID#: 5285
1 hr per side of the car if all is good, then an hour for the head. You then have the danger of needing the head skimming if it isn't flat which can throw more delays and cost at you.
To be fair, I don't believe in ripping the engine apart unless something is wrong. If your going this far, have you considered a full rebuild? Forged pistons etc?
Old 05-10-2006, 08:17 PM   #7
Nino_Brown
Alloy Junkie
Nino_Brown's Avatar
Drives: 350gt
Club ID#: 6900
Country Flag
http://cgi.ebay.com/ebaymotors/Tomei...spagenameZWD1V
Are these the cams i want?
__________________
Old 05-10-2006, 08:21 PM   #8
Nino_Brown
Alloy Junkie
Nino_Brown's Avatar
Drives: 350gt
Club ID#: 6900
Country Flag
Ek!
Not prepared to go down that route just yet.....didnt realise there was so much work involved in the HG...
The dude at the garage says that the stock gasket would limit the boost i could run, fair enough. But ive raised the subject on here before, and Todd was said he didnt advise his customers to go the HG route....
So im not sure if the guy us trying to get more work out, or if i dont go for the gasket then limit the boost he tunes the car too
__________________
Old 05-10-2006, 08:23 PM   #9
SPEARMINT
Banned from Site
Club ID#: 5285
Looks like it, I would confirm it with Andy W as he fits these all the time. I'm pretty sure I have the version 1's installed.
Old 05-10-2006, 08:23 PM   #10
SPEARMINT
Banned from Site
Club ID#: 5285
Nino, the boost you want to run...is it more than 1.2BAR?
Old 05-10-2006, 08:30 PM   #11
Nino_Brown
Alloy Junkie
Nino_Brown's Avatar
Drives: 350gt
Club ID#: 6900
Country Flag
Nope
__________________
Old 05-10-2006, 08:31 PM   #12
Nino_Brown
Alloy Junkie
Nino_Brown's Avatar
Drives: 350gt
Club ID#: 6900
Country Flag
What about just fitting cams...that a big job on its own without the HG?
__________________
Old 05-10-2006, 08:35 PM   #13
SPEARMINT
Banned from Site
Club ID#: 5285
If your not going to run more then 1.2BAR, don't bother changing the HG unless it goes.
As for cams, not the hardest job but you need to know what your doing.
Old 05-10-2006, 08:37 PM   #14
Nino_Brown
Alloy Junkie
Nino_Brown's Avatar
Drives: 350gt
Club ID#: 6900
Country Flag
So the money i save on the HG, i could use on the cams...
Hmmmmm
__________________
Old 05-10-2006, 08:50 PM   #15
ivor
Registered User
ivor's Avatar
Drives: R33 GTS-T
Club ID#: 4712
you'll probably find them cheaper in the uk as well or at nengun for £260
http://www.nengun.com/catalogue/product/38
__________________
SP AUTOS BUILT GT-ART TUNED NO KNOCK AND 400BHP
ivor is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Clutch supply and fitting LOCKYGTS Tuning, Technical Questions 1 23-04-2006 01:45 AM
Haltech Engine management for your skyline innovate performance Authorised Traders 5 25-08-2005 01:30 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 SkylineOwners.Com Ltd
Page generated in 0.65057 seconds with 16 queries
