Go Back   Skyline Owners Forum > Technical / Performance / Maintenance / Help > Tuning, Technical Questions
Forum Rules Register Garage Online Shop Calendar Mark Forums Read
Tuning, Technical Questions Use this Forum to talk about all things technical & tuning
Reply
Thread Tools Rate Thread
Old 10-11-2006, 04:34 PM   #16
dellaruse
Skinny Alien
dellaruse's Avatar
Drives: peugeot 407sw & caravan & missing the Skyline
Club ID#: 2418
Country Flag
Quote:
Originally Posted by T.F.S.
knock normally increases the further up the rev range you go, a rise with RPM is not a problem as it is normally engine noise not knock
what we really need to take notice of is a sharp increase in knock that seems to come out of the blue, then you know its detonation
thinking about it det in 5th could also be caused by the fuel rail depressureising, one of my customers done this with his nitrous kit.....fuelling was fine but in 5th over a long distance the pressure dropped and fuelling was not sufficient
please note: i know nothing about cars or engines so ignore everything i have said
Will fitting fuel pressure reg solve it?
__________________
SKYLINEOWNERS.COM
Keith
mygarage
dellaruse is offline   Reply With Quote
Old 10-11-2006, 04:39 PM   #17
Bill Oddie
Banned from SOC
Moderator
Bill Oddie's Avatar
Drives: 5.0 V8
Club ID#: 5685
Quote:
im not saying it is the fuel, just that it might be
to check this you need wideband or at least a fuel pressure guage (see rebuild thread under "seting up and performance")
a fuel pressure regulator would not solve this if this was the case, you would need a better pump or the same pump with correct live (sometimes the pump only sees 10 volts rather than 12 due to age)
the regulator can increase pressure but only because it RESTRICTS flow, more pressure....less fuel from the pump
please note: i know nothing about engines or cars, ignore my comments
Bill Oddie is offline   Reply With Quote
Old 10-11-2006, 04:51 PM   #18
Richf
Banned from Site
Club ID#: 6399
TFS could be onto something there , i'm getting the feeling my fuel pump is struggling now and i see from your garage that you also run a GTR pump abd run similar power
400hp is probably getting to the limit on them it might be time for an upgrade
Richf is offline   Reply With Quote
Old 10-11-2006, 04:53 PM   #19
N=8
N=8's Avatar
Drives: E39 540i
Club ID#: 742
Was it mapped on a dyno or on the road?
You could be using a cell in the ignition map that has not been mapped because the load on the engine on a dyno is different to on the road. It may just need a bit of fine tuning to the ignition map and a degree or two taken out of those cells.
__________________
If it ain't broke... you're not driving fast enough!
N=8 is offline   Reply With Quote
Old 10-11-2006, 05:05 PM   #20
dellaruse
Skinny Alien
dellaruse's Avatar
Club ID#: 2418
Country Flag
Got it mapped on the dyno a month ago and have been back this morning for a check and this was done on the road, and some of the cells where fine tuned! but on the way back it started to happen again!!
Keith
__________________
SKYLINEOWNERS.COM
Keith
mygarage
Old 10-11-2006, 05:06 PM   #21
dellaruse
Skinny Alien
dellaruse's Avatar
Club ID#: 2418
Country Flag
i thought these were good for 400+ tho Rich!
__________________
SKYLINEOWNERS.COM
Keith
mygarage
Old 10-11-2006, 05:09 PM   #22
Richf
Banned from Site
Club ID#: 6399
so did i but i'm no longer convinced.
Old 10-11-2006, 05:10 PM   #23
dellaruse
Skinny Alien
dellaruse's Avatar
Club ID#: 2418
Country Flag
Any recomendations on pumps
__________________
SKYLINEOWNERS.COM
Keith
mygarage
Old 10-11-2006, 05:11 PM   #24
SPEARMINT
Banned from Site
Drives: 1996 R33 GTS-T S2
Club ID#: 5285
I might just have a look at this water injection lark.
T.F.S, seeing as you know the square route of **** all, what kit would you recommend?
SPEARMINT is offline   Reply With Quote
Old 10-11-2006, 05:16 PM   #25
dellaruse
Skinny Alien
dellaruse's Avatar
Club ID#: 2418
Country Flag
Mr mint
what fuel pump you running??
__________________
SKYLINEOWNERS.COM
Keith
mygarage
Old 10-11-2006, 05:21 PM   #26
SPEARMINT
Banned from Site
Club ID#: 5285
Nismo 280 litre per hour jobba thingy.
Old 10-11-2006, 05:23 PM   #27
Bill Oddie
Banned from SOC
Moderator
Bill Oddie's Avatar
Drives: 5.0 V8
Club ID#: 5685
lol
i use an aquamist but the best system i think is a noswizards system as injection rate rises with boost pressure but it needs a pressureised cylinder/bottle and this is normally metal, not great for alcahol
i will PM you with some info as you know im not allowed to post guides on here
the best advice will be from "JohnA" of the aquamist forum, a good friend of mine and also a mentor, speak to him!
precompressor injection is the way forward but im doing mine just before plenium
Old 10-11-2006, 05:24 PM   #28
dellaruse
Skinny Alien
dellaruse's Avatar
Club ID#: 2418
Country Flag
Anyone know what lph the GTR one's are then?
__________________
SKYLINEOWNERS.COM
Keith
mygarage
Old 10-11-2006, 05:25 PM   #29
Richf
Banned from Site
Club ID#: 6399
thats what i am going for
Old 10-11-2006, 05:29 PM   #30
SPEARMINT
Banned from Site
Club ID#: 5285
lol
Yes, please do.
So, pros and cons of before the plenum or before the compressor section? What would they be?
Reply
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Skyline Rb20 Rb25 Det High Mount Manifold carnology Parts for Sale 4 20-02-2006 10:46 PM
PowerFC det levels petemillis General 5 31-05-2005 06:19 PM
Help - with breathing on a high power GTR GEORGEGTS Tuning, Technical Questions 2 27-02-2005 11:26 PM
Juddering in high gear @ low rev's. GAV 111S Tuning, Technical Questions 7 18-01-2005 04:31 AM
high revs bad running ,poping stealth69 Tuning, Technical Questions 6 25-11-2004 12:24 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 SkylineOwners.Com Ltd
Page generated in 0.96754 seconds with 16 queries
