Quote:
Originally Posted by Richf
My experience was spannering on Big Chiefs car , we disabled the water injection and he ran 6mph faster in the 1/4
By the sounds of it you were using water as well as using fuel to cool the cylinder so the engine is going to scrub power!, if you even read the link you would see that you need to go lean and advance for extra power otherwise there is little point running WI
water is 5 times better at picking heat up from the cylinder, the extra fuel that is injected into the cylinder over stoich on a turbo car is only there to remove heat and reduce det, we replace the fuel with a far better coolant and as a result AFR drops and power increases......any mixture over stoich results in the excess fuel being blown out of the exhaust
as i have said i use WI because without it my car will det, if like your friend i had a UK map that didnt det then i wouldnt fit WI unless i intended to advance the ignition slightly, the methanol gives me an increase in octane exactly when i need it too.....triggered at 0.61bar
its a bit like someone saying they wouldnt use nitrous because they once used a kit that was jetted far too rich and it never worked, we know its the person playing with the kit that is the problem not the kit itself, some people wont even take advice from the people who designed the kits anyway so maybe this is falling on deaf ears lol
Water -- Oxygen content 0% (ignoring dissolved oxygen) Latent heat of Vaporization 2259 KJ/kg . K = 539.6 BTU/lb . F
Methanol -- Oxygen content 49.9% by wt, latent heat of vaporization 1099 KJ/Kg . K = 262.6 BTU/lb . F
Ethanol ----- Oxygen content 34.7% by wt, latent heat of vaporization 854 KJ/kg . K = 204.1 BTU/lb . F
Isopropyl --C3H8O--- Oxygen content 26.66% by wt, latent heat of vaporization 666 KJ/kg . K = 159.24 BTU/lb . F
Petrol -- About 586-628 KJ/kg . K ---- 140 -150 BTU/lb . F depending on fuel blend
Nitrous Oxide -- 376 kJ/kg
