Go Back   Skyline Owners Forum > Technical / Performance / Maintenance / Help > Tuning, Technical Questions
Forum Rules Register New Garage Online Shop Calendar Mark Forums Read
Tuning, Technical Questions Use this Forum to talk about all things technical & tuning
Reply
Thread Tools Rate Thread
Old 28-12-2006, 08:15 PM   #1
Allkiller
Allkiller No Filler
Allkiller's Avatar
Drives: R33 GTS-t,
Club ID#: 6675
Turbo expert needed
I have been offered this turbo cheap, its a Rayjay T4 Hybrid
Its a RAJAY model no 301E80 it has a .8 AR its like a T4 hybrid
The wastegate is a Roto-master Mod No 225-112B-15V
The turbo was fitted on a car for a while, then re-conditioned and never run since.
Anyone know if it will work, fitting wise, or anything about it power wise ??
thanks
Click image for larger version
ID:	29933   Click image for larger version
ID:	29934   Click image for larger version
__________________
Capable of evading high speed pursuit
OO\____/OO
http://zippy.qiqpiq.com/c9mavatar79197.jpg
Allkiller is offline   Reply With Quote Share on facebook
Old 30-12-2006, 12:00 AM   #2
ivor
Registered User
ivor's Avatar
Drives: R33 GTS-T
Club ID#: 4712
the standard manifold is t3 as far as i know, to run this i would say your going to need a top mount manifold with a ake of for the wastegate then you'll need to get someone to knock you up the downpipe section as well,thats about as much i can tell you.
__________________
SP AUTOS BUILT GT-ART TUNED NO KNOCK AND 400BHP
ivor is offline   Reply With Quote
Old 30-12-2006, 12:14 AM   #3
Allkiller
Allkiller No Filler
Allkiller's Avatar
Drives: R33 GTS-t,
Club ID#: 6675
Many thanks, someone else has since told me that they are not very efficient turbos and are hard to get spares or repaired.
Also very poor spool up capability....so i wont be going for it
Ivor
i really want to know what the Garrett version of the HKS 2835 is can you help here.
__________________
OO\____/OO
Old 30-12-2006, 12:32 AM   #4
ivor
Registered User
ivor's Avatar
Drives: R33 GTS-T
Club ID#: 4712
2835 is what is going on mine next month hopefully it's a direct replacement and has a good spool up time if you buy the kit from nengun you get everything you need. I'm also getting a set of pon cams and hoping to break the 400bhp barrier the full turbo kit costs around £1200 and takes a couple of weeks to get here
http://www.nengun.com/forced-inducti...nissan-skyline
__________________
Old 30-12-2006, 11:36 AM   #5
NISFAN
NISFAN's Avatar
Drives: Skyline GTS R33
Club ID#: 484
RAYJAY - lol, that is one old sucker.
RAYJAY were bought by Garrett donkeys ago, IIRC.
NISFAN is offline   Reply With Quote
Old 30-12-2006, 01:45 PM   #6
SPEARMINT
Banned from Site
Drives: 1996 R33 GTS-T S2
Club ID#: 5285
Thought about Billet Turbo's?
SPEARMINT is offline   Reply With Quote
Old 30-12-2006, 02:36 PM   #7
Allkiller
Allkiller No Filler
Allkiller's Avatar
Drives: R33 GTS-t,
Club ID#: 6675
Ivor , im gonna look into that kit ....Cams...do i need em ??
What lift IN / EX, are the Pon cams, still varing duration i guess
Spearmint....Kerching....aint in that league, leave that for you guys
Nisfan, they only do Aircraft stuff now....as i sort of said not a good turbo by modern standards....
__________________
OO\____/OO
Old 30-12-2006, 03:03 PM   #8
iansr33
na power :)
iansr33's Avatar
Drives: Black 33 GTST
Club ID#: 9563
Country Flag
Can you let me know what the kit is like please ivor when it arrives.
iansr33 is offline   Reply With Quote
Old 30-12-2006, 03:17 PM   #9
Allkiller
Allkiller No Filler
Allkiller's Avatar
Drives: R33 GTS-t,
Club ID#: 6675
Ian your avatar must be Yoghurt by now....
__________________
OO\____/OO
Old 30-12-2006, 03:20 PM   #10
Allkiller
Allkiller No Filler
Allkiller's Avatar
Drives: R33 GTS-t,
Club ID#: 6675
__________________
OO\____/OO
Old 30-12-2006, 03:38 PM   #11
Allkiller
Allkiller No Filler
Allkiller's Avatar
Drives: R33 GTS-t,
Club ID#: 6675
__________________
OO\____/OO
Old 30-12-2006, 06:54 PM   #12
ivor
Registered User
ivor's Avatar
Drives: R33 GTS-T
Club ID#: 4712
the cams are 256 duration with 8.5mm lift this is as far as you can realistically go without loosing your nvcs.
It's really upto to personal choice as to wether you want cams or not i'm getting mine because i want to increase the torque of the engine
Ian once i get the kit i'll photograph it and post up before i have the work carried out i want. Andy at sp will be fitting it for me and he reckons there an easy fit
__________________
Old 30-12-2006, 07:04 PM   #13
Allkiller
Allkiller No Filler
Allkiller's Avatar
Drives: R33 GTS-t,
Club ID#: 6675
Ivor, that would be great...really worried about spitting my turbo out only running .72 bar or 10.5 psi that should be ok ?? Yes
__________________
OO\____/OO
Old 30-12-2006, 08:07 PM   #14
ivor
Registered User
ivor's Avatar
Drives: R33 GTS-T
Club ID#: 4712
yes .72 will be okay
__________________
Reply
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
greddy turbo timer install help needed pleeeeease r33nik Tuning, Technical Questions 5 11-08-2006 03:11 PM
Apexi RHX-6 turbo gaskets needed urgently!! Chris Wilson Tuning, Technical Questions 0 11-05-2006 01:40 PM
new turbo needed richy Tuning, Technical Questions 2 30-05-2005 10:51 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 SkylineOwners.Com Ltd
Page generated in 0.53910 seconds with 17 queries
