1 - 20 of 20 Posts
violence IS the answer!
Hi guys, i dont wanna sound like a spanner or owt but ive just bought a can of 10k boost spray additive, has anybody got any ideas where i would need to spray it? My engine is an RB25 DET. there are different ways of applying it for different engines, it says to spray it into the turbo inlet. which pipe goes to the inlet side of the turbo?
cheers very muchly guys! :boobies:
as i've never heard of it i assume the best thing to do would be spray it about ten feet away from your turbo til the can is empty then spend your cash on something better :D
how can you say it wont, its ment to clean the inside of your engine and may help a bit with emissions test. have you actually tried this chris?
Discussion Starter · #8 ·
Just used it on mine after fooookin about with a pair of tights over the inlet cos i dint fancy sprayin it through my AFM! after reading and following all the destructions, id done it. now for the moment of truth.... set off, hit boost and i fooookin shat my pants! it started spluttering and a MAHOOOSIVE cloud of smoke came out of the exhaust! spluttered in second and third but as soon as i got to fourth it had cleared and the difference was noticable straight away! it runs a lot smoother and the throttle response felt a lot crisper. Well happy with my purchase. i recommend it!
sounds all good then, and at only twenty quid it may help alot of people out come mot time.
Forum Thug
Tights eh?:grinno:
Your meant to spray it into the turbo inlet just after the AFM so you dont damage this and it'll clean all your pipes, inlet manifold, valves etc.
I've used this on my pulsar, 306 D-turbo, Golf GTI mk2 8v + 16v, MK3 TDI, Alfa 156 clover leaf, and it definately always made a difference bt more so on the diesels and NA engines as i feel the boost on the pulsar kept everything clean anyways, but if your skyline has had a turbo blow or been driven fairly soft this stuff will work and make a difference.
Track addict
No i haven't, and i still wouldn't. I'm always doubtfull of ebay specials.
But thats just my opinion. I never said it wouldn't work, just that i had my doubts.
Discussion Starter · #14 ·
It picks up a hell of a lot better in second third and fourth now! I didnt buy it off E-bay, i just used the link so people knew what it was.
I still recommend it though, but if you are gonna use it, make sure you put a pair of tights over the inlet when you take the AFM off otherwise it just keeps cutting out, then just cut a hole in the tights and sprey it through that!
personally i use redex
Redex goes in the fuel system and wont clean out your turbo, boost pipes, inlet manifold etc
Redex is for valves, injectors etc
All you need to do is quickly adjust your throttle cable so it idles higher.
Subsequent to reading a review on this and similar products I obtained some from www.Speeding.co.uk. I paid a bit more than £20 but it certainly works, you only had to watch the exhaust for a few minutes after adding it!
I wouldn't claim a 10bhp improvement but things certainly appeared sharper after treatment. How convinced am I?, well I'd use it again..and at £25 a can I think that's a fair recommendation.
Aitch
1 - 20 of 20 Posts
