Hi all,
Does anyone know if a 19" 9.5j with a 20 ET fit on the rear of a GT without needing arches rolled? Its got a 275/35 tyre.
And std suspension?
I have worked out the tyre with stick out 33mm more and rim 32mm more that the std 17" 8j ET 33 with 235/50 tyre
Thanks.
Although i cant remember 100% i am pretty sure that's the same size/offset i had on mine, and i went on to fit spacers, then it needed slight arch work.
I'm running 19x10s at ET35 with a 20mm spacer (so same as ET15) on the rear - no probs.
So 19x9.5 with ET20 will fit fine then, I had a measure up and I was 100% sure the arches would need rolling (which I don't want to do).
Thanks.
