Hi guys,
My stock turbo just blew (I think there's little ceramic turbine chunks in my cat right now) and I am considering a power upgrade on a 1996 R33 Skyline (manual trans with the RB25DET)
I am torn between options for ECU, fuel injectors, EBC etc.
At the moment it seems that the most economical way to go about getting the most horsepower for my money would be to:
- high-flow the turbo (HyperGear turbos in Australia)
- get a Nistune-d Z32 ECU and a Z32 AFM
or
- get a R33 RB25DET Apexi Power FC + OLED hand controller
- pick up some second hand S15 SR20DET 480cc injectors
- Cheap HDI EBC/Gizzmo EBC
Mods I currently have worth mentioning:
- Turnflow intercooler
- Pod filter with heatshield airbox
- 3" exhaust from the turbo
- Walbro 255Lph in-tank fuel pump
- 53mm Koyo Aluminium radiator
- Splitfire Super Direct Ignition Coilpacks
- NGK Iridium spark plugs
- Turbosmart BOV (recirculated)
- Stock intercooler and intake piping
How much power can I expect out of this ECU/injector/turbo upgrade? Very roughly on RON 98 pump fuel?
P.S. If Power FC is the way to go, is it worth going the D'Jetro (MAP and IAT sensor) way so I can vent my BOV to atmosphere and vent my cam breathers to atmosphere without stuffing up the AFM sensor which is used by the Nistuned ECU and the L'Jetro (MAF)?
EDIT: I have just been advised by Nengun that the PowerFC (both D'Jetro and L'Jetro) with the new OLED controllers are actually built specifically by Apexi for the ECR33, and not modded BCNR33 ones.
or
