hey guys just wanting a few suggestions on what might be making my exhaust manifolds crack out so quickley if use could through any ideas my way it would be much appreciated thnx
stock manifold stock turbo all bolts done up tight everything was done by the by the book both timesWhat make are they? OEM? What turbo you have on it? Are the nuts torqued properly?
Wrong they will, excess engine move movement will crack a manifold, as I found out, the skyline exhaust is a CRAP design with no flexi join in the downpipe.age of the manifold and nothing more
snapped engine mounts wont cause it as the downpipe is bolted to the gearbox so its solid and also the reason for rubber exhaust mounts
