ok i'm trying to make sense of the instructions i got with my profec e01 boost controller and i need to know 2 things? my car is an r33 gts25t
first: is my solanoid valve a single or dual port actuator
secondly: do i have an external wastegate or an actuator type
(to fit the pressure valve)
if its standard turbo then you'll have an actuator, you'd no if you have a external wastegate by the noise and the fact that you'll have a different manifold as well, dont no about the solanoid but trying to be helpful!!
i have this controller on my 32 gtr don't be suprised if the automatic setup dosen't work
i set mine up manually and it made a real difference you can set the boost in 500rpm increments mine spools up great now when you get it set up properly you will be impressed !!!i'm sure
that depends on if i can fit the dam thing! i'm good with bodywork not engines so trying to make head or tail of this is giving me a headache. having the same problem with trying to wire in that apexi multichecker
