1 - 14 of 14 Posts
as above i have a couple of spare apexi power fc,s no commanders, afm type.
will get the numbers of them if anybody needs them
looking for 375 each + del..bernie
33gtr fitment
Discussion Starter · #11 ·
apparently yes?. you,ll need to make your lambda wire into two wires and the same for you maf wire. maybe someone can shed light on if it can be done?. bernie.
p.s got interest on the blue site so maybe only one left, if they do fit others julio will have first bite as he asked first guys,
ive been reading, and the problem with the gtr pfc is that you loose the nvcs.
The GTR PFC on the GTST loose's low/high fuel pump speed and runs constant high.
The bonus you get from the rb26 pfc is that you can use the air temp sensor input, cuz the rb25 doesnt have that input.
the problem with the nvcs can be fixed by putting a Auto switching unit between the loom, so that you can set up the nvcs manually. from 1800rpm to 5700rpm.
So i think ill pass, going to find some other ecu.
1 - 14 of 14 Posts
