2 Nights ago i went over a pot hole, causing a short circuit. As a result, i had to tow it from the break down location to the nearest auto electrician who did jack all, then had to tow it again to another mechanic who found out the wiring for the steering wheel has been damaged and also the ECU unit being blown. Cost of this was already $1000. BUT later i found out the $1500 advanti rims were cracked from the impact, so i now have to get new set of wheels for $1500.
This all was caused by the BLOODY **** SUSPENSIONS i had from the previous owner in japan before importing.
I would like to prevent this incident from happening again by replacing the suspensions. Would there be any CHEAP ones you guys would recommend? Should i use coil overs?
