im about to order my new disk ready for my journey down to the pod on
oct 7th, now the disks i have are 324mm x 28mm thick, the new ones im looking at say new thickness 30mm ,,, minimun thickness 28mm, i know its only 2mm but i dont know **** about brakes so im a lttle concerned will 2 mm cause problems or is it good for me to make my order????
if it effects any answers im running r34 brembo front calipers
and im ordering r33 disks as they are both the same thing ???
disks will be a cheap ebc jobby as im brasic at the mo, im planning on red stuff pads or yellow stuff
please some 1 tell me if 2mm is a issue as i want to order them asap so i can fitt them in time ,
mr poohpants
The 30mm discs should fit OK, they will just take a bit more squeezing in the first place! It just means the pistons will be pushed back 1mm either side further than with standard discs, no problem really. Benefit will be better heat dissipation so braking will improve a little.
Aitch
and my gts-t runs r32 gtr front disks no problem and there 2mm thicker buddy:D
thanks guys, , its always best to check these things b4 hand,,, :) :) :)
Hmm, just checked the specs and the R33 Gt-R should have the 30mm discs anyway..full spec below:
324 x 53.75 x 30 x 68 x 5 stud for R33 GT-R's 1/1995>
This is the same as the R32 GT-R 8/1993 - 12/1994 which also has the same 324 x 53.75 x 30 x 68 x 5 stud
The other options are from the 350Z 2003>, 324 x 49 x 30 x 68 x 5 stud..
There is no 28mm thick disc listed for Skylines..though of course that is the specified minimum thickness, relating of course to worn discs.
So the only real issue is to make sure you get the 53.75mm overall depth discs not the 49mm.
Aitch
I would guess thats a R32 V-Spec, (would also tie up better with the dates), as that came with Brembos, normal R32 GTR brakes are smaller than R33/34 ones.
Alex B
yea there showing 54 not 53.75 , but im sure that will be as good as ,lol
cheers for ya help dudes
