1 - 18 of 18 Posts
Yep you can and there are a few different types of std turbo cant remember which is the better to have sure clarkey was selling the better one a while back.
there all T3 flanges
one from a 34 is even better so im told
GTT, i was told that GTR ones are smaller because they have two so they dont need to be as big
the turbo in a spec 2 is the same as a spec 1, the r33 gtst turbo is slightly bigger than the 32 one but is a straight fit as far as im aware and it gives a bit more midrange, just remember to swap the actuators over too as the 32 one is set for 0.8 bar and the 33 one is set for 0.7 bar max.
Space Filler
It's only really worth doing if the 33 has steel internals. Plus I believe the actuator on 33 turbos is set a bit lower than the 32 one so I think you'd find the car having to do a bit more work just to boost to the same levels.
The R34 GTT will fit on and its the biggest of the RB25 engines.
depends what you want to use your car for i suppose. Personally i'd rather have power lower in the rev range. How often do we get a chance to really go flat to the board anyway with our crap roads
Amen to that comment not even fit for tractors
1 - 18 of 18 Posts
