1 - 20 of 21 Posts
Does anyone know if the heater controls(the bit with the buttons on) from the gtst(one with the top corner cut off on right) fit the gtr i.e- Are the plugs the same as im after a double din stereo but would need to swap these over cos i dont want to relocate the one i have...any help would be gr8 peeps
Daz
yes they fit if you swap the dash bit over too
what you going to do about the three gauges though
Discussion Starter · #4 ·
Getting shut of em as the turbo gauge is stuck on "0" atm... why do i need to change the dash bit tho as the dash is interchangeable int it
because you will have a gap at the top right of the controls
why dont you put the three gauges in the glove box
Discussion Starter · #6 ·
What do you mean by a gap on the top right? is that were the cut off bit is?
yeah that bit
the boost gauge will be more than likely no pipe on the sender
Discussion Starter · #9 ·
But the three gauges have the same cut off on it so dont see why it wouldnt fit
Discussion Starter · #10 ·
do you know where the sender is? as ive not a jar of glue... funny thing is ive only noticed it since my alarm was done mmmmm wonder if somerts come off at the back
the sender on mine is near the vin plate
let me look at some pics a min of your dash, your getting me confused now
i thought the gauges were square edge's all around them and dont have the corner cut off
Discussion Starter · #13 · (Edited)
found out why the boost gauge isnt working the alarm guys have broke the pipe which runs from the sender to the engine(to be fair its really brittle) just got to get some vac pipe and it shud be sorted yay!!!
Wonder if this would cause the idle to run high as it were fine when i got the car?
yes daz it would cause it to idle high
contact matt at boostjunkies on here he will sort you out
Discussion Starter · #15 ·
Ian you do come in useful for some things nice one mate... Now that this is hopefully sorted im gonna get a single din size stereo with flip up touch 7" screen+gps+freeview yay!!!
a single din would be far easier fella and wont look silly as you can just put the screen away when not needed like i do with mine
Discussion Starter · #17 ·
I were thinking that too seen a nice one on ebay but its £350 which for the extras isnt that bad plus it has a detachable face too.
save up fella and get a proper one that aint from ebay and is a good brand
Discussion Starter · #19 ·
Its a blaupunkt i think which is a good brand its so cheep cos he bought a massive stock
yeah there ok
just not some brand you cant say the name of though lol
1 - 20 of 21 Posts
