Hi All,
Thinking about part changing my transmission fluid on my 350GT Auto(heard full flush is not recommened), I've looked around and Nissan Matic S is what is recommend, but unfortunately no one sells it in the UK!
From reading around the Castrol 06814 Transmax Import Multi-Vehicle Automatic Transmission Fluid matches the Matic S spec
https://www.amazon.com/Castrol-06814-Multi-Vehicle-Automatic-Transmission/dp/B00826N5JW?tag=vs-auto-insert-amazon-20
According to this link the CASTROL TRANSMAX FE MULTIVEHICLE fluid also matches Castrol Transmax FE Multivehicle | Castrol Australia | Automatic Transmission Fluid (ATF) - Car Products | Castrol Australia | Car - Motor Oil & Lubricants | Castrol Australia | Products | Castrol Australia | Castrol? Engine Oil & Lubricants - Castro
Does anyone have a cheap UK supplier or can anyone recommend an equiv fluid they have used, also freom what I've read 3-5Ltr replacement is recommended?
You can buy it (or its direct OEM replacement) from Clark Motorsport, topped mine up last service, no problems
Hi Sai,thanks for the advice, What did you buy? doesn't look like they stock matic S? just J for ~£20/litre!
Sorry for th belated reply, not on here much these days
Just checked at my unit.....
Alex from the 350z forum also sticks all OEM fluids
