well as title suggests im lloking to fit 9.5x18 offset is 22 to my gts-t first of all is it possible with out any mods? im also putting coilovers in the car is that helps any
rab :cheers:
er no. i have 8.5x17 with a offset of 18 and they stuck out on the front by about 2cm so i dont think you will be able to at all with out wider wings and arches
yea so id o have gtr offset wheels :D
if you have pillow ball top mounts, adjusting them makes no difference to the camber on the front of an r33 gtst!! you need camber top arm things for that and yes i am right because i fitted coilovers last week and the bottom of the coilovers only has one mounting bolts which the coilover can move on. it face back to front so moving the top of the coilover in will do nothing.
