1 - 20 of 23 Posts
OK for the hardcore professional car mechanics are going to laugh this off but i'm well stoked with my efforts.......
Finally got round to removing the 4 sheared exhaust manifold stud in the beast....
It took me all afternoon & last time i try this I ended up having to have the work correct professionally :devil:. After a lots of swearing cursing I ended up with these :)
New studs are in, new gasket ready just reading up on my torque tightnesses to put it all back together....
DS
hi
now elongate the holes in the manifold in the direction the bolts have been making contact by 2mm and it wont happen again
ive had that happen i welded nuts and spanners on and while they were still hot they came out with ease
wardy
Cheers Folks!
So, how did you get the bits out?
easyouts??
Yes m8. Cobalt drill bit, Halfords "Shock & Unlock" & easy out's!
1/2 turn on the easy out, blast of "shock & unlock", repeat. Took ages but well proud.....
Thought about doing something like that but decided if you increased the bore you risk reducing the snugness of the new bolt fit (which in turn could introduce vibration to the head<->manifold = damage).
Opted to use standard bolts & upgraded gasket, only aiming for 400bhp on my car & the STD nissan R33 gtst exhaust manifold is good for near 500bhp...
DS
Jammy Git
That's good going. I had my own battle with that a few months back and felt totally righteous afterwards!!
Jedi skills :)
Thats cool mate.
Hope the website helped
we tryied that shock and unlock stuff and found it crap
Frezze and release was so much better
My old man swears by the stuff now lol
Discussion Starter #12
@ Everyone, cheers. Yep does feel real good to do the job myself.
My ebay "unbranded" uprated turbo elbow arrvied this afternoon, turns out to be a exotic speed (http://www.exoticspeed.ca/about_us.php) one! Well happy :)
Yep it was my source of info to get going. Would have used Freeze 'n Release if I could source some in time.....
DS
with the freeze stuff
do you have the engine warm and spray the broken stud?
No I just squirted as much as I could on a cold engine stud waited for it to "crack" and un done it.
Would advise you re check the bolts after about a week found the end one needed to be re torqued.
right then
im getting loads of the freeze stuff from work :)
Discussion Starter #16
Like j_jskyline79 said, use it when cold (you really don't want to start the engine with turbo oil lines removed........)
DS
derrr
do you really think im going to start the car with the turbo off tut tut
i will quickly strip it after i turn it off
Discussion Starter #18
lol - you must be good, it took me about 30mins just to get the oil & water feeds off the turbo (without damaging them). I was being uber careful mind you as it was my first attempt at that job...
Unless you've got your engine red hot before you start the job, I think you'll find the majority of the heat has dissipated before you get near the good components....
If you do manage to get 'em off in time, you'll need thick glove to hold the hot components (I hate working in latex thin gloves yet alone heat resistance thick jobbies...)
Good luck!
DS
Yeap Dad said it took him about that long with a 24mm stepped ring spanner
Can be done a bit easyer if you remove the power steering out the way, just remove brackets then a 24mm socket should fit in there
Dont forget new copper washers
4 for the water and 2 for the oil
Car Abuser
I was quoted over £600 to get this done, who fancies doing it for me? Anyone near the Essex/Lakeside area?
My car's sounded like a tractor for months now. It's embarrassing.
1 - 20 of 23 Posts
