hi all, after getting my r32 gts through an m.o.t i noticed whilst on the ramp that the drivers side rear wheel has more camber and toe than tthe passenger side. I have no idea how this has happened but is now visible from standing behind the car. I have looked at adjustable rear camber arms to correct this, however when i hav taken the wheel off to have a look i cant see any damaged/bent arms or any damage to the hub, which is putting me in two minds as to what to do. I heard somewhere that the camber can be minorly adjusted through a bolt on the rear, is it feasable that this just needs adjusting back to the original place? or is there no such bolt?
The camber is only slightly more then the other side, more noticeable as i now have the r32 lowered on tein's, and i like having camber, just not different degree's on different sides,
any help would be much appreciated
duane
duane
