Hi, would like to know ... what kind petrol injectors are in my RB25DE spec 2 and RB 25 DET spec 2 ?? For upgrade, could i use GTS-T injectors ??? I think there is more petrol feed. I have uprated fuel pump installed already.
tha
You would need a few serious mods on an n/a to justify upgrading the injectors
Why do you think you need them?
spec 1 rb25de are 270cc,spec 1 rb25det are 370cc,can't see why spec 2 would be different,and the same as what badhabit said you'll need some serious mods the 270's to run out of puff, they where still fine when i first fitted a turbo to my na with a fpr
What makes you think you need to upgrade your injectors in the first place?
na car wont need an injector upgrade unless you turbo it.
if its still na then they wont need changing.
