If any of you could see what already been done you may understand, the aim is to drastically reduce body weight, ABS is just one item.
I wonder what people did before they developed ABS?
I've removed it from my drift car, you don't need a new master cylinder, you just need to split the pipe for the front brakes into 2.
Thats all you really need to do, remove the ABS unit, bin the brake lines, then run the front pipe out of the master cylinder into a 1 into 2 splitter, (as in the picture above), then from that run one to each caliper. Then the rear into the block, located on the front O/S chassis rail.
You will need to remove the ABS sensors from the front hubs and rear diff and blank the holes off, otherwise you could fail the MOT for the ABS not working, which you shouldn't if it's not fitted.
Alex B
Edit: You can see the block for the rear brake line behing the slpitter block, thats there as standard.
