B
Guest
Hi gang ..
just thinkin about this 'ere drag day we got comin ... what kind of suspension settings will help with the launch ?? ...
forgive me im new to all this tech stuff but if i am correct in thinking that drift cars use rock solid suspension settings then would a drag car use a slightly softer set up ? ... to help minimise wheelspin ?
ta !!!!
S
Hi Steve,
You are spot on, a car with rockhard suspension will not launch as well as a car with softer suspension. Unless you are planning to run slicks....
yep run semi slicks get your launch right u will need soft tyres
and soft suspension
B
Guest
ta chaps ..
k .. daft question time ... is it an easy job adjusting the suspension ? .. the set up i've got is HKS Hypermax II ... tried lookin on the net but drawn a blank.
taa
