1 - 2 of 2 Posts
Plug & Play Engine Management Systems FAQs...
AEM's Plug & Play Engine Management System (EMS) plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (2000, XP, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. An integrated tuning wizard allows users to create a base map specifically for a car’s configuration, regardless of what type of injectors, sensors, coils or other changes have been made. The AEM EMS's infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
To download the latest version of the AEMPro Software: CLICK HERE.
Installs in minutes using Plug & Play technology—no wiring necessary!
Start-up calibrations included
Live help window eases tuning process
Set-up Wizard creates a custom base map for your car
System is fully enabled—Never pay for upgrades!
Free software updates on aempower.com
Uses all the factory sensors
Runs on Windows™ compatible software
Fuel table automapping
Programmable traction control
Onboard 512kb datalogger
Up to 10 cylinder sequential fuel injection
16 general-purpose outputs
7 definable switch inputs
Electronic boost control
Soft cut rev limiters
Two step launch control
Wet or dry nitrous control
Definable knock control
Full idle control
4 EGT inputs with fuel control
16/32 hybrid high speed processor
it is the nuts
i want £500 for it fits R32 GTS-T thinks also R33 and R34 with RB25DET but you will have to make sure
pm me:D
1 - 2 of 2 Posts
