Hi everyone
Firstly any responses would be great and much appreciated! :)
So I have a R33 skyline rb25det. Forged engine, standard crank. Bought the car off a friend so I know it's been done.
So I have full HKS turbo back exhaust with downpipe.
Big front mount intercooler.
Apexi intake.
Apexi boost controller.
Split fire coil packs.
NGK iridium spark plugs heat 7.
I'm wanting to buy plazmaman intake with 90mm throttle body.
Walbro 255 high pressure fuel pump
3mm Top mount manifold and 50mm v-band waste gate.
Not to sure on the turbo just yet any help with that would be great!
I know not alot, but I'm going to get rid of the apexi boost controller and replace with a G4 Link ecu which I have already bought. But wanting to know what you guys would recommend for the 450/500bhp plus all other small supporting mods I would need!
Any help would be great thanks again!
I was going the same with my r34 GTT
Blitz boost controller, blitz induction kit, jasma exhaust system
Bought a link G4+ an had it mapped at 300 for now
But to get to 550 I'm told by my mapper I need
Fit front mount ( will map again to 330 )
Walbro pump
Gtr injectors
Precision5858 turbo
External wastegate
6boost manifold
My car is the 2.5det neo engine
First things first, do you want 450bhp or 500bhp as they are two different things and different ways of getting there. Also if the engine is forged why limit yourself to 500bhp when a built engine could do more.
I also wouldnt bother with a 90mm throttle body. 72mm will be plenty and Plazmaman themself run over 1000bhp on the 72mm.
I have 6Boost RB25DET manifolds in stock and European distributor for Plazmaman. Also keep stock of fuel pumps, turbos and pretty much everything else you will need for your chosen power goals. Package deals or finance deals are also available :)
I can't recommend 6boost enough really helpful guy and knows his stuff and sells what you need to get you to your target whatever you decide on
