1 - 20 of 20 Posts
Are there any mathematical genious out there who can tell me what the equation is to work out the volume of air in litres used per minute at 6000rpm per litre capacity of engine size.
I think that sounds right, but you may have to read it twice to understand it.
Cheers peeps :D
M's Factory
Hint : Piston Sizing x stroke length x revolutions x 6 ( cos yer got six of em init ;)
I have tried the route of 2.5ltr capacity x 6000rpm and got 15000ltr per minute. This seems a hell of alot of air, but then again am i thinking to hard.
Based on the premise of 15000 litrs a minute, thats 530 CFM, in compressor terms thats a bigun. You would need a 120HP electric motor to get that from a compressor. Now that throws up more questions than answers .
M's Factory
bish bash bosh :)
doesn't the fact that a compressor (turbo) is thrown into the mix make the whole calc extremely complex!
No not a turbo just an ordinary old industrial air compressor. Just trying to get a relationship into perspective between the air displaced or swept by the engine and something I (and maybe a few others) would know for comparison on how much air is moved.
Sorry buster, I wasn't actually relating to your post about compressors in that way. You post just got me thinking about the turbo....
N
Guest
Ah buster , but its not compressing the air , 2 storage , at say 100 psi, if ya get my drift
True enough Martin Nitesky but the compression on a cylinder is usually 120 psi. I was thinking more about the volume of air.
A piston compressor does have to overcome a rising air pressure as it fills a tank and the size of a compressor is measured in the volume of air it can deliver at a set pressure, hence a Halfords cigarette lighter job can give 120 psi, but it would nver run an air sander.
Just trying to get my head around the relevant horse powers between an engine at 300 ish and a compressor at 120 for the same volume of air.
I know I will shut up before my brain fries.
N
Guest
think on single cly then , on the down stroke after bang , exhaust
, then inlet , say a 100 cc piston , that air is at atmosphere , untill compression , so its still 100cc of air
does that sound right .
Not to forget that not all the exhaust gasses are expelled from the cylinder on the exhaust stroke ,something to do with improved emissions/combustion and valve overlaps etc. Hell I can't remember it's years since I was at college doing engineering and it was more fun getting drunk and educating the local female population than paying attention.:guiness: :guiness: :boobies:
Discussion Starter #17
Thanks guys, I think my heads popped on this one.
I will try the cylinder capacity route in cc's and convert to cfm and down to Ltrs.p.m
I hope this gives me the answer to my problem. If so I will let you in on the results and benefits in store.
"A Skyline with 4 doors?"
Here's a link to a great site for trying to calculate all of these figures for you!
http://www.turbofast.com.au/tfcalc.html
This is what I used to figure out the fuel pump flow and injector size I require for my vehicle.
The Engine uses 1 litre air per sekond and horsepower
Ex , 400hp=400ltr Air/sec
That is an easy way to calculate the airconsumption if you know the horsepower
its close enough if you want to know airfiltersize,Turbosize
and such ,But if you need to know the exact Airconsumption
to calculate engine efficiency or something like that ,
you will need a LOT of different engine data
Regards Maxout
Discussion Starter #20
Big thanks Maxout, I can move forward on my project now and hopefully post a thread to give the results in the next few week.
Thanks to all for your help
1 - 20 of 20 Posts
