1 - 20 of 20 Posts
fresh built- RBS13 430bhp Drift car
(RB25DET) 2.5- straight six - 24v -variable valve timing- turbo charged - + tuned!
Full skyline running gear + tuning parts!
This car started life as a standard 1994- Lreg 200sx s13 1.8 turbo till last year when we (Drift-Art.com) got hold of it.
it was striped down to a bare shell a rebuilt into the hybrid 430bhp drift monster.
here is a list of parts to give you a idea of the spec & cost as it is:
Stock 200sxS13 in good condtion with no rust.......£1000.00
fiberglass drift front bumper
fiberglass drift rear bumper
fiberglass drift side skirts ......................................£1000.00
fiberglass drift 20mm wider front vented wings.......£275.00
fiberglass drift 50mm wider rear quarters...............£250.00
old rear arches modified (labour)
modified vented bonnet (labour)
bonnet pins.....................................................£20.00
Full respray ...................................................£1,000.00
large drift rear wing ........................................£350.00
Rear wheel spacers hubcentric 30mm...............£100.00
Pair of cobra bucket seats...............................£200.00
4-point harneses.............................................£50.00
Led Side lights & front indicators.....................£60.00
Boost gauge & oil pressure gauges & twin piller pod........£100.00
VEMS A/F ratio Gauge with wideband lambda & EGT ....£270.00
Drift release hand break button........................£10.00
Harness hooks............................................£5.00
custom head lights (crystal).....................................£50.00
custom rear lights............................................£100.00
18x9j Alloy wheels ET20 ............................£1000.00
stretch tyres 225/45/18...............................£300.00
skyline alloy 4pot front callipers & discs..........£150.00
skyline alloy rear discs & callipers..............£100.00
skyline clutch master cylinder
skyline clutch slave cylinder
skyline brake master cylinder
skyline brake servo
abs system removed (labour)
200sx s14 front 5-stud hubs ..............£150.00
skyline 5-stud rear hubs.....................£150.00
rose jointed & adjustable rear Castor arms..
rose jointed & adjustable rear Camber arms...
rose jointed & adjustable rear Toeing arms....
rose jointed & adjustable front Castor arms........£350.00
all rose joints greased with gaiters........£30.00
alloy sub-frame locking collers.......£30.00
drift height adjustable (track use only) coil-overs....... £500.00
front camber adjustable top mounts..............£50.00
rose jointed adjustable track rod ends......£100.00
modified s13 steering rack with spacers and tein track rods for extra steering lock....£30.00
rear strut brace........£30.00
uprated front anti-roll bar..........£150.00
uprated rear anti-roll bar...........£50.00
solid alloy steering bush........£20.00
omp steering wheel & spacer.....£100.00
blacked out rear windows.....£30.00
rear end all striped out & painted black...£20.00
battery relocated to boot.......£50.00
Full skyline R33 GTST N-reg 40k miles...........£2,800.00
full rb25det skyline engine conversion (removed from a 40k mile skyline)
skyline modified wire loom.....(labour)
walbro 255lph race fuel pump..........................£100.00
full 3" turbo back skyline exhaust system...........£350.00
3" decat pipe...................................................£50.00
1.5mm Tommi metal head gasket......................£150.00
blitz cone air filter with hard pipe.......................£150.00
apexi AVC-r boost controller set @1.3bar high & 1.0bar low boost...£280.00
stage 3 rising sun performance turbo...................£1,110.00
braided turbo oil feed........................................£20.00
z32 air flow meter.............................................£150.00
550cc injectors..6x............................................£300.00
Splitfire coilpacks x6..........................................£300.00
modified inlet manifold......................................£150.00
adjustable fuel pressure regulator........................£50.00
apexi power fc stand alone ecu + commander ....£1,000.00
Full remap by Richard @ rsp ...........................£450.00
samco boost pipes............................................£50.00
custom boost pipe kit........................................£100.00
R34 gtr re-cored front mount intercooler............£300.00
koyo racing alloy radiator ................................£200.00
twin 12" kenlow fans with temp control.............£100.00
oil catch tank...................................................£70.00
full service kit & oils ect..................................£300.00
air con removed......(labour)
6-puk paddle clutch...........................................£350.00
custom prop-shaft............................................£207.00
gearbox custom mounts..................................£50.00
skyline shimmed rear lsd diff ...........................£150.00
diff oil cooler
skyline drive-shafts
alarm & immobiliser ................£300.00
its currently has all the geometry set up on a full drift set up by :wheels in motion
there`s properly loads of things Ive missed but gives the general idea of how much time and effort & money has been put into this machine.
its not for the faint hearted it running 430.6bhp with dyno sheets to prove, its had major weight reduction also so the power to weight ratio is pretty good.
I've spent well over £17k on this as you can see and that's with out the labour so afraid it wont be sold for peanuts as i will Rather keep it. not in any hurry to sell so keep the silly offers.
will come with 12mths mot & 6mths tax
feel free too ask any think i may have forgotten
this is built as a track/ drift car not a show car, it does have some tatty looking bits as all track cars do.
viewing is welcome & recommended but afraid not test drivers.
BUY NOW IS £10.000. ono
pictures here:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=280324419308
South West (England 13)
Absolutely gorgeous car - just a shame the market is so poor at the moment
TBH 10k seems a bargain to me - but I already have 4 cars :(
Would be nice though - looks lovely
1 - 20 of 20 Posts
