Where's the cheapest place to get some alu sheet in 3mm and also some 3mm angled tube? :smoker:
T Top Cat · Guest Joined Jan 1, 1970 · 0 Posts Discussion Starter • #1 • Dec 22, 2012 Where's the cheapest place to get some alu sheet in 3mm and also some 3mm angled tube? :smoker:
L lammy426 · Premium Member Joined Sep 21, 2006 · 1,936 Posts #2 • Dec 22, 2012 a steel stockist,if it was me i'd try steelstock near buton-on-trent if they don't have it they would put you in the right direction
240kGT · Seasoned Member Joined Oct 25, 2012 · 941 Posts #3 • Dec 22, 2012 Birmingham and Coventry are surrounded by Engineering works so you'll pick some up close to you with no problems.
L lammy426 · Premium Member Joined Sep 21, 2006 · 1,936 Posts #4 • Dec 22, 2012 how much are you looking for
T Top Cat · Guest Joined Jan 1, 1970 · 0 Posts Discussion Starter • #5 • Dec 22, 2012 I have it sorted now gents. Talk amongst yourselves.
Poirot · Punch me. Joined Oct 4, 2005 · 9,398 Posts #6 • Dec 22, 2012 I have an inch thick slab of high grade ally indoors...**** knows what im going to do with it!
T Top Cat · Guest Joined Jan 1, 1970 · 0 Posts Discussion Starter • #7 • Dec 22, 2012 A whole inch huh? I only require a 3mm thick plate.
R rossmcleod · Registered Joined Dec 9, 2007 · 9,236 Posts #8 • Dec 22, 2012 Can't beat a bit of inch
T Top Cat · Guest Joined Jan 1, 1970 · 0 Posts Discussion Starter • #9 • Dec 22, 2012 That's gay bro.
