Status
Not open for further replies.
1 - 14 of 14 Posts
· Seasoned Member
We're feeling generous here at Driftworks HQ at the moment. There is currently 10% off individual arms and now an EXTRA 10% off 4 arm kits!
Kits seen here: http://www.driftworks.com/catalogsearch/result/?q=4+arm+kit
(R33 GTS-T 4 arm kit in picture)
The Driftworks 4 Arm Kit Comprises of -
2 Tension Rods - Adjust Castor and replace the large worn out Nissan bush *Geomaster tension rods optional.
2 Camber Arms - Adjust rear camber for the correct tyre contact patch on lowered cars and remove worn Nissan Bush
2 Toe arms with HICAS removal kit - Adjust your rear toe correctly on lowered cars and remove worn Nissan bush, remove and lock out HICAS.
2 Traction Rods - Adjust geometry change under compression and remove worn Nissan Bush
What better time is there to treat your Skyline to some fancy footwork? :cheers:
Any questions/queries then please don't hesitate to contact us via email at [email protected] , call us on 0845 86 92 555 or just drop me a pm. Cheers!
· Seasoned Member
Discussion Starter · #6 ·
1 - 14 of 14 Posts
Status
