i have a r33 gtst and when i brought it the speedo was nt working after loads of dash board stripping i found the problem to be under the car. it should have a sensor with a gear on it that plugs in under the gearbox, but mine had a old cable type transducer in the place were the sensor should be but it does have the plug there to connect the speed sensor back up. so i have asked about and was told there is a chance i have the r32 box for some reason and all i need to do is replace the transducer for a r33 speed sensor. i have just brought one but it looks loads longer than the one thats in there at the moment can any one help?? please
