I've just refitted the original steering wheel and airbag for the MOT, but now the airbag light is flashing at me!
I've tried all the door light tricks i can find online but none will work for me!
Anyone got any other ideas or able to help me out?
Cheers.
Quicker to just take the clocks out and remove the airbag light bulb than mess about with steering wheels ect
Why you changing it for MOT anyway??? Makes no sense
I had an aftermarket wheel fitted and that had the airbag light flashing. Never bothered me, but the mot station failed it for no airbag and the fault light on.... Bummer! So now i've stuck the original one back in to get it through but the light still flashes despite having the original airbag in.
Any suggestions?
May need the airbag control unit resetting. Try disconnecting the battery, Turning the ignition on and pressing the brake pedal so it take the juice out of everything then reconnecting it. This MAY reset the airbag ecu, I do say MAY!
Worth a try.....
Thought the new MOT rules were that the tester had to see the light come on (as it should with the ignition turned on) and then go out after 5 seconds.
Means you need the right rating of resistor that matches what the resistance of the Airbag is so you can fit it into the plug to fool the ECU into thinking the airbag is there.
HTH,
Russell
Scotland Area Rep Aberdeenshire
Worth a try.....
when fitting the steering wheels you should of disconnected the battery this should work
Turn the ignition to electric on but don't start the engine. Soon as you see the airbag light come on and blink off then turn the power off immediately. Repeat 5 times and then start the engine.
