confused.com
yeah which bit is it you mean?
confused.com
not too difficult, two bolts you can see, unplug the sensor that's clips to the horizontal support bracket.
undo the cam sensor and with draw. (mark up where the bolts are first, so you get em back in the same place on the cover, as rotating it changes the ignition timing I'm told)
one/possibly awkward bolt underneath somewhere.
putting it back on is the fiddly bit as it sits over the lower cover.
si.
sounds simple enough, no doubt there will be a huge drama at some point during this excercise
