1 - 3 of 3 Posts
Here's me engine specs...
Engine:
Blitz FMIC with hardpipe and silicon hoses
Blitz SUS air filter with adaptor kit
Full reconditioned coil pack
Spec 2 engine
Trust exhaust system - all the way to the turbo elbow
Hi-flow racing cat
Just bought a Greddy Profec II and an Apexi Neo, but wondering if there is anything else I should do/buy before getting it all set up? Fuel pump, FPR, Z32 AFM etc, etc??
Ex Skylineowner
Depends how deep your pockets are and what you want from the car. Bearing in mind every time you change something, to get the most out of it, it'll need set up again so it's probably best to change as much as possible towards your goals as possible to minimise the amount of times you need get need a tune.
Well I plan on getting the boost controller and Neo setup. (unless other stuff is advised).
Then sort interior etc. After that I will be going for a stage 3 hybrid turbo.
Worth getting anything else. Basically, is there anything I could/should get now to make the setup as is better once setup?
Or leave the rest until hybrid turbo?
1 - 3 of 3 Posts
