S
Guest
Two issues with an Apexi Turbo Timer I installed at the weekend, the first is that I need to know which wire to splice into on the ECU for the lambda sensor reading and it only ever gives me the minimum time when set to the 'auto' mode.
can anyone help?
(R33 GTSt)
Simon
you can trace the lambda wire back to the ecu from the sensor, can't remember the colour, I'll have a look 2moro
"A Skyline with 4 doors?"
If you have the same one I've got, the one with the seperate thin silver controller, I can help you out! If it's the older model I don't have the info.
Here's the link to the wiring installation, just look up the R33 (diagram N4-a).
http://www.apexi-usa.com/productdocumentation/electronics_autotimer.pdf
And here's the link to the instruction manual for it:
http://www.apexi-usa.com/productdocumentation/autoTimerInstructions.pdf
One thing, it says to wire the ground to the ECU, I tried that and it would not work. Instead connect the timer's ground to the body. So you should only have one wire connected to your ECU harness.
I hope this is what you're looking for!
S
Guest
you know what? - I never even thought to look on the apexi website - doh!!
thanks for that - now if only it wasn't pi$$ing it down........
Simo
