hi guys. i have a pipe with a banjo end coming from the 4wd solinoids/pumps which i was told used to go to the rear diff housing. the previous owner had to change the rear diff and the original housing wouldn`t fit to the diff he had gotten. because it`s lying loose, the 4wd oil just pumps out of it in seconds. Does anyone know if i can just block it off, or does it need to be part of a circuitory system, as i can`t see anywhere else that a return feed would fit/go.
thanks
thanks
