1 - 2 of 2 Posts
My speed reading on my AVC-R has stopped working today.
Not sure why...
Has anyone had this problem before and found a resolution....
Ill get my manual out when i get home and see what it says...
Hopfully it wont be in Japanese...
Well if it has been working with no probs before and then stopped it will more than likely be a faulty connection. Check the wire from AVC-R that goes to the speed signal wire of your ECU. Don´t use the clips, it is better to solder the wires and then tape them.
Some people have problems with the speed reading of the AVC-R after having fitted a speedo converter chip. Some see half the speed only etc. So this might be worth to check too. Although I doubt in your case it´s important as you don´t get any reading at all.
1 - 2 of 2 Posts
