I just spent the day hooking up an AVC-R, and when I fired the car up, everything seemed to be working ok, apart from the speed monitor on it. Only then did I notice my main dash speedo had died. I tried taking the speed wire from the avcr loom back off the ecu, but the dash one still was kaput. I've definitely spliced into the correct wire, and only heated the wire long enough to flow the solder over the join.
I'm not sure if I've made a boo-boo, or if the speedo dying was purely a co-incidence. Anyone got any ideas on what/how I can check?
