Anyone got a Bee*R rev limiter fitted to an R32 GTST with RB20 DET engine and standard ecu?
I've ben trying to fit mine, (well the electrician has!) but can't get it to work, we've followed the usual instructions, using wires 41 and 42 or 51 and 52, but it doesn't cut the revs.
Anyone had similar problems?
Alex B
paul from jap imports had one on his bee-r 324 when it came in from japan with the rb20 engine,
so i know they can work,
Yeah I know they can work and I know this one was working as I had it fitted to my GTR for a year.
Basically, we're struggling to find which wires to connect it to in the ecu, we've found the crank sensor wires, but when connected to those it doesn't do anything.
I ideally need an ECU pinout for an R32 GTST.
Alex B
Alex B
Ex Skylineowner
Definately work. Heres a pinout for you - link. Runing mine:
yellow -41
green -42
red -49
black - 50
Hmm, will have to spend a bit of time trying to sort it out, we've tried those pins, will have to properly wire it in and give it a run.
Does anyone know if the unit itself can be tested? It was working perfectly when I took it out of the GTR and it's been sat in a box since.
Alex B
