very subtle :p does the bee*r affect the engine at all?
if it's not abused and setup properly it's supposed to be better for it than a fuel cut limiter.
but limiting @ 3.5k revs and hammering it won't be "good" for any engine fuel or ignition cut and will take it's toll eventually, even in 2 second bursts
most common problem i hear is the oil pump failing and ceramic turbos letting go, along with any gaskets from the outlet back.
but it's a cheap way for building boost for launch with spectacular side-effects.
