what is it for does it alter the rev limt ie rev higher?
It is a very basic form of launch control - just allows you set a rev limit for while the handbrake is on.It allows you to adjust the point at which the rev limiter cuts in also the amount of time it cuts in for,not only that it cuts the spark and not the fuel as the standard limiter does which is suppose to be better for the engine.
It also has a launch control capability.
When you hit it, big noise, flames and poppage ensues! :devil:I've heard that a car backfires more violently when it hits a bee r limiter. Is there any truth in this?
