Naz Ali
cars due a service soon...whats best type of oil to use on the rb20e ..would 10-40 castoral gtx be ok? ALSO how much oil do i need for an oil change.,
10w/40 semi synthetic will fine and is what i use, also castrol recommend 10w/40too,they take around 4.3 ltrs with a filter change,bung 4.0 ltrs in then just top it up to the dipstick mark...
Naz Ali
can i carry on using 10-40 castoral gtx in my 2.0na...even though now its high mileage 127k miles and engines slightly ticky(ticky like a normal engine) but before it was so quiet you couldnt hear it running
some people said to use thicker oil and some said thinner for some reason....but i dont know??? any suggestions on what i should do??
Naz Ali
no reply guess ill stick with 10w-40 castoral...i just thought 15w-40 might have been better at 127,000 miles on a standard 2.0 non turbo engine
No difference between 10w-40 and 15w-40 in terms of how well it will look after your engine except at startup.
The 15w and the 10w just refers to how thick the oil is when cold.
Once warmed up both oils are the same viscosity... i.e. look after your engine just as well.
Nissan specified 7.5w-30, so a 40 weight oil is better for a hard pressed engine with a few miles on the clock ;)
