Hi Guys,
Ok im building my RB25DET engine for my 200sx and have a bit of a shopping list for you. Be greatfull if you could price it up and when you could get the parts etc. Im looking around Jan to order it all
Tomei Poncam kit Inlet/Ex 8.5mm lift:
Tomei Valve springs 8.8mm:
1.8mm Head gasket:
Nissan engine gasket set:
ARP stud and nut kit for the cyl head:
Nissan oil pump:
Nissan water pump:
Nissan thermostat or Nismo cold running one? :
Tomei cambelt or something like that:
Idler and tensioner pulley for cambelt:
ACL or something you would recommend for the Main bearings/Thrust washers and big end bearings:
ARP con rod bolts or just use original? :
RB25 exhaust manifold stud and nut kit:
Ok thats it so far also will be buying your ECU Upgrade for the RB25 ecu and you turbo kit when you bring it out
Looking to run around 500bhp
So if all good prices looks like everything will come from you :dogpile:
Cheers,
Andy
1.8mm Head gasket:
Nissan oil pump:
Nissan water pump:
Cheers,
Andy
