Bit of help needed...
339 Views 6 Replies 2 Participants Last post by  Top Cat
Hi there has anyone ever wired one of these up? If so could do with some help and advice so I can wire this one up, many thanks Mick.
I do Im afraid Topcat :) saves having loads of different gauges to be looking at
I haven't but I would say you're going to have to tap into your ecu to pick up the RPM, power/illumination take offs from the ignition circuit, one from the oil sender unit and one from the boost.
Cheers guys, by the way its going into a 32, topcat was that for the rpm mate? And carbon thanks matey :)
G
All of it. RPM signal, +12v, Ground and illumination. Whatever your left with are signal in's for the rest of the gauges. Simples. :)
