now then all.just bought my first r33 gts and there is a bleed valve on it and i personaly dont think it is plumbed in right can someone please tell me how it should be conected standard without bleed valve and also what is the hicas.thanks
hicas is the rear wheel steering and you will need the boost solinoid and the little restrictor to set it back to standard, its prob easyer to get a electronic boost controller
i think these parts are still there just need to know where the vacuum pipes should go. the bleed valve is between intercooler pipe and actuator.
well the restricter is a little brass bit inside a short pipe, i will take some pics for you tomorrow ans post them up
