As there are no proper rear arch replacements to be found for reasonable money, Does anyone know of a panel off another car that comes close so I can at least get it bodged?
Yes, I'm aware. The thing is that, since I can't do the cutting and welding myself I suspect it's going to be COSTLY (yes, caps). That's why my idea was to get the rust cut away but the welding doesn't have to be perfect and then have the fiberglass panel to cover it up (which I would be fine with). Although, I'm still waiting for a quote on the panel job.This Knightracer one is a fibreglass panel and is different than a GTST. It's styled on the wider GTR panels which is fine if that's the look you want but if you've got a standard GTST then to make it look right you'd need all the other GTR replica panels for the rest of the car. Even then you'd still have the original (rusty?) panel underneath this as it just attaches on to the standard panel.
