I just a bought a 1993 r33 gtst-t skyline and the stock boost does not work.I'm new to the turbo and skylines,if you can can tell me where to look a nd what line are for the gauge.thanks
to be honest the stock boost gauge is about as accurate as seaweed, and after market one would be a lot better.
you could have a look in the engine bay just in front the driver attached to the suspension tower is a small black box (boost sensor) it my be disconnected or the pipe from the plenum may have come of or split.
the stock gauge is very accurate,all three of my gtst's were pretty much spot on with aftermarket gauges,its just a matter of being able to convert the stock mm/hg to bar (or psi if you wish) and the fact that the stock gauge is not as clear as aftermarket ones.
in a nutshell if you are at 7 on the stock gauge then you are running at the limits of the turbo as 7 is 0.93 bar
I don't know why they use mmHg because it's an absolute pressure unit and they're using it as gauge pressure. The zero on the gauge should really be about 750 - 760mmHg (atmospheric pressure) and at complete vacuum it should read zero.
how do you figure that ,0 is 0 regardless of what unit you are using to measure pressure,-760mm/hg is the equivelant of -1.01bar
Zero is not zero, it depends if the unit is an absolute pressure reading or a gauge pressure reading. A gauge pressure reading will read zero at atmosphere, whereas an absolute pressure reading will read zero when under full vacuum conditions.
Millimeters Mercury (mmHg) is an absolute pressure unit, not a gauge unit, so on a day like today the pressure is 757.40mmHg. At complete vacuum, the pressure would be 0mmHg. There's no such thing as -760mmHg and that's why the standard boost pressure gauge is misleading.
T
Guest
Hi bud Welcome to the forum. :)
In answer to your question Id say either try to get another little factory gauge and check your fuses also (just in case its that simple ;).)
Failing that its easier than you think to fit a new aftermaket boost gauge. :cheers:
TC
It's a bit of a long shot, but when i put in some OEL dials on my clocks, i got the standard boost gauge pointer/needle the wrong side of the stopper, consequently it wouldn't move from the bottom. Someone might have taken out your speedo head to put in a delimiter and the same happened...
