1 - 10 of 10 Posts
FORUM FARTER!!!!
has anyone got a boots nipple that go on the japspeed fmic need one so i can fit if tx boys
did you not get the little brass t bit?
you use the t bit and put it into the pipe running from the inlet to the carbon canister.
FORUM FARTER!!!!
Discussion Starter · #6 ·
got a brass t bar but japspeed said i need a boots nipple from apexi as the new pipe has nowhere for it to go
you mean apex performance as i told paul :) ( i was there when you phoned ) the t bit will do for now. the t bit goes into the small pipe leading to the carbon canister, but like you i got a boost nipple from apex in the traders, only around eight quid, you then make a small hole in the intake pipe between the new pipe and old pipe, put the nipple through and tighten the nut down. sometimes when you use the t bit it plays up. do you have a boost controller?
and its spelt boost :)
no probs, if you do still have the standard boost solinoid you need to keep the short pipe as it has a restrictor in it allowing you to run 0.7 bar of boost during second stage. if you remove this pipe when fitting the new front mount you will only get 0.5 bar all the way.
1 - 10 of 10 Posts
