Hi guys,
Its been a while since ive posted on here but I'm in need of your help.
My r33 gtst's bottom end is knocking, not ideal with show season coming up.
I was wondering what you guys would recommend me doing.. Do I rebuild my current rb25? Or do i get a new (second hand) engine?
Which ever option i go for i know i want more power. I was running 317bhp before it went wrong. Now I may as well upgrade whilst its out and I want at least 400-450. I already have a free flow exhaust, air filter, intercooler etc.
I think i need a uprated turbo (hyrbid one??),550cc injectors and better spark plugs, head gasket and then a ecu and map. Is there anything else?
What sort of price am I realistically looking at for a rebuild? And then costs for the extra parts aswell?
Any help is appreciated as this is all completely new to me ?
Buy a know good running engine and fit that.
Then rebuild your current engine then swap.
If you are handy you could rebuild it yourself.
See auto extreme for all your parts
Terry
Well i am no mechanic but a bottom end knock could be a simple re-shell if not run too much and caused damage to crank. This would not cost a great deal but any second hand engine could have similar issues down the line if you dont know its history and could set you back min of £1500 up to 2k.
To up the power will cost you as much too as you say injectors, turbo, fuel pump poss head gasket (although i understand head gasket should be good for 400 -450) and remap of ecu or go LinkG4 or some other stand alone ecu.
I would go with basic rebuild for now get car back on the road then weigh up options before committing. Hope this helps.
If the bottom end has got to the point that you can hear it then its going to need a regrind and re-shell at a minimum .
West Sussex Area Rep
Have you had it 100% diagnosed as bottom end?
I thought mine had gone not long ago and turned out it was just a bearing on the cambelt tensioner.
