1996 R33 GTS-T
I'd like to know if any special tools are required to take off the brake discs on an R33 gts-t
i know on my old car i needed an impact screw driver to take out the screws that held the front discs in place.
Also, i read that skylines use a seperate drum brake for the E-brake instead of just using the rear brake pads/discs.... What kind of maintenance is required for these as i've never worked on drum brakes before.... And my e-brake is really worn out, i need to pull it ALL THE WAY up for it to do much....
Any help would be greatly appreciated
No special tools needed mate, once you've removed the calipers they pretty much fall off.
Don't know much about the hand brake other than I believe the adjuster for it is under the centre console, so unless you've run out of adjustment there I'd pretty much leave the rest of it alone.
