Hey hello people , I am trying to replace my brake rotors but i do not want to order the wrong one, so , can anybody tell me the specifications for a 1996 R33 GTS-4 (the one in my profile pic). And if they are compatible with 240sx brake rotors. Thanks in advance.....:CHEERS:
confused.com
the 240 sx rotors are thinner (by a difference of 2mm if memory serves) so will not work ..as youll over extend your caliper pistons ...what you need are either a set of DBA discs, or I THINK CONCEPTUA may be able to sort you out with a set of OEM or aftermarket ones.
search my old thread on her and those from a guy called aitch ...we did allthe figureing out years back but the sizes escape me...
296mm Diameter i think.....
Give Chris at Conceptua Tuning on here a shout and he´ll sort you out.
Tuned by RSP
witch 240 sx are u speaking about?? the s13?
none, because the s13 has 4 hole hub
